While it's nice to see rotary more integrated into Aspire, my initial impression is that I've lost a lot of capabilities in V9.5 and will probably continue to do my rotary work in V9.0.
In V9.0 I could choose to preview my rotary toolpaths wrapped or unwrapped. Both views are extremely useful to me when developing a rotary project. Unwrapped I can quickly scan the entire design for issues like carving depth and such without having to twiddle around. Aspire does not display coordinate data when previewing the rotary / wrapped models (or I haven't figured out how to turn this feature on yet). I want to be able to check carving depths (Z) and coordinates by hovering over the preview. Without the ability to preview unwrapped, I can't do this in V9.5.
Switching back and forth between V9.0 and V9.5 seems to trigger the Migrate Dialog at startup each time. Wish I could turn that off and I hope that just ignoring / closing the dialog is not causing me any problems.
Ed
V9.5 Rotary First Impression
- Model of CNC Machine: Taig Mill and Self Built Routers
Re: V9.5 Rotary First Impression
Watch the "What's new" video. It should change your mind.
You can switch between the wrapped and unwrapped views.Aspire does not display coordinate data when previewing the rotary / wrapped models (or I haven't figured out how to turn this feature on yet). I want to be able to check carving depths (Z) and coordinates by hovering over the preview. Without the ability to preview unwrapped, I can't do this in V9.5.
The unwrapped view shows the Z values you are looking for.
Gary and Randall - Thanks for the help. I looked all over for a way to unwrap this morning. Somehow managed to overlook the button at the top and spent all my time looking through menus and the icons/buttons on the left. Now that I know I can unwrap I would agree that V9.5 rotary support is vastly superior to prior versions, but the thing I'm most excited about is the handling of text. The ability to edit without losing all the formatting is a HUGE improvement. Sure wish I had that feature for a project I did last week.
Thanks again.
Ed
Thanks again.
Ed
- Vectric Staff
- Model of CNC Machine: Various
Hi All,
Other than the What's New Video, we have created quite a lot of tutorials specifically on Rotary: https://support.vectric.com/tutorials/V ... rds=rotary
I hope this helps
I hope this helps
Beki
Senior Application Engineer - Vectric Ltd.
