Joining vectors - need help
CNCGreg
Model of CNC Machine: Techno LC 4896
Post by CNCGreg »
Hand Plane 3D.crv3d
(51.5 KiB) Downloaded 144 times
I am trying to Join the Hand Plane vectors in the attached file but am not having success. Does anyone see the problem as to why the Vectors will not Join?
Greg
ger21
Re: Joining vectors - need help
Post by ger21 »
You can only join them at their ends, so if the ends don't meet, you can't joint them.
Why do you need to joint them?
Post by highpockets »
What vectors are you trying to join?
What is your vision for the final to look like?
Post by Rcnewcomb »
Depending on what you want, you may not need to join the vectors. The image below was made by choosing Profile ON the vectors with a 90 degree V bit at 1/16" depth of cut.
Hand Plane 3DV02.crv3d
(278 KiB) Downloaded 122 times
CNCGreg
Post by CNCGreg »
When I go to the tool path and select the object to v-carve I get the msg "29 open vectors were identified in the selection and are being ignored. There are 5 remaining vectors" When I run the calculate it only picks the 5 vectors to carve.
Randall, I cannot get it to cut the v-carve you posted.
John, my vision was to have a 3D carving of the hand plane raised in the oval area. I am new to the 3D and Aspire. Don't hold it against me, I was a MasterCam user and am enjoying Aspire now. Many tutorials to watch and learn.
Greg
Don't use the V-Carve toolpath. Use the profile toolpath set to be On the vector.
Greg,
I can't hold being new against anyone. I'm learning new stuff all the time, that's part of the fun.
Here's a little bit of a different approach. You have Aspire, use it....
This is just a down and dirty model.
Post by Rcnewcomb »
In my post above I included the Aspire file so you can download it and see my toolpath.
ger21
Post by ger21 »
You're not going to be able to V Carve that without extensive vector editing. But I don't think you really would want to V Carve it, as it probably wouldn't look very good.
Here's one just a little better, I forgot to set the Modeling Resolution correctly :oops: :oops: :oops:
Expanding a bit on Randall's suggestion.....
CNCGreg
Post by CNCGreg »
Thanks Everyone. Yes, Adrian, I just tried the V carve with the Profile 'On' the object line and it worked. So I am able to V carve the plane as Randall did.
John, the 3D that you did is what I had in mind. Then you 'tricked out' Randall's V carve. That's cool also. Did you offset the outside profile to get the bevel cut around the plane and inside the handle area? Would you mind sharing your files so I can see what you did? Are there any specific Vectric Tutorials that would explain what you did? I have viewed a few but have not been successful in what you did.
CNCGreg wrote:John, the 3D that you did is what I had in mind. Then you 'tricked out' Randall's V carve. That's cool also. Did you offset the outside profile to get the bevel cut around the plane and inside the handle area? Would you mind sharing your files so I can see what you did? Are there any specific Vectric Tutorials that would explain what you did? I have viewed a few but have not been successful in what you did.
Greg, on Randall's V-Carve I created a copy of the original plane then deleted all the vectors not part of the outline, then using the welding tools an node editing I created a closed vector outline. I used the offset tool to move the outline 1/4" out.
Hand Plane 3D-2.crv3d
(1.47 MiB) Downloaded 105 times
For the 2.5D model I searched for a picture of a plane similar to the one in your project.
After some Photoshop work I used Create component from selected or imported bitmap Modeling tool to create a component of the plane. After some smoothing and Sculpting I had a rough component to use. Needs more tweaking, but it's a start...
Wood Plane.crv3d
(1.29 MiB) Downloaded 112 times
Go to the Vectric's website and start working through the tutorials.
CNCGreg
Post by CNCGreg »
Thanks John. I downloaded the files and will work with them. Can a Create Component be created from a vector dwg as the hand plane was drawn or does it have to come from a bitmap? I've tried a few of the Create Component icons but to no avail. I will review the tutorials.
Greg
Greg,
Create a component from a selected or imported bitmap pretty much says it all. You can only use a bitmap image to create a component.
Now, what you could do is save the plane as a bitmap then use the Create a component from a selected or imported bitmap tool.
