1Hi,
I'm make a text, put it to double hight, and then I want to use "Text On A Curve" but it keeps is original size instead!
How can I make a double high text in a curve!
Regards
J. Pedersen
Make text double height in a curve
Re: Make text double height in a curve
Any changes you make to text sizing are lost when you perform another text based operation so you would need to size the text after the curve operation or use the distortion tool instead.
Adrian: Thanks for the tips.
I got a friend to make the text in adobe illustrator fir me.
