Question about offset
mark-s
Model of CNC Machine: diy 4 X 4 CNC Router
Post by mark-s »
Say I offset lower left and enter 2X 2Y.
Is that where the center of my object will be?
mark-s
Phil
Re: Question about offset
Post by Phil »
Not clear on what you are asking. I'd suggest that you experiment with what you are describing and see if you can answer your question.
Phil
mark-s
Post by mark-s »
Then could you explain how to use the offset or how it works please.
Is there a video of how to use offset.
I would like to do a 3d carve and it requires a roughing path
and a cleaning path.
mark-s
Post by Rcnewcomb »
I would like to do a 3d carve and it requires a roughing path and a FINISHING path.
Look at the Lioness video tutorial at about the 5 minute mark.
Post by highpockets »
mark-s wrote:Then could you explain how to use the offset or how it works please.
mark-s
The best way to understand the Boundary Offset is to play with the setting and observe the preview.
Here's generally what I do.
On roughing toolpath, I use a boundary Offset equal to the bit diameter and a Machine Allowance of .02"
On finishing toolpath I use a Boundary Offset equal to at least half the diameter of the bit plus just a little more. Example if I'm using a .0625 ball nose bit I'll set the Boundary Offset to .07.
How this helps.
mark-s
Post by mark-s »
Thanks for the reply's.
mark-s
From the original question I thought that the question was about the offset on the job setup not about boundary offsets in 3D toolpaths. Just goes to show that we need as much info in the first post as possible.
mark-s
Post by mark-s »
Would like info on that (offset on the job setup) as well.
Thank You
mark-s
Best place to start is with the interactive Help (Help Contents). You can click on the icons that you want help with and then it will take you to a page that explains each option.
