Curved face and rabbet Mission Drawer Front
Postby wwoodworks » Thu Jun 28, 2018 6:43 am
I am trying to create toolpaths to carve a convex face on a Shaker drawer front.
The outside edges to be 1" and the center 3/4" when carved.
The rabbet in the back is cut such that once a panel is installed in the frame, there is an
even 1/4" reveal face to panel viewing from the front
Any ideas on how to approach such a project?
wwoodworks
Model of CNC Machine: Shark Pro Plus & Shopmaster 4848
Re: Curved face and rabbet Mission Drawer Front
Postby Martin Reid » Thu Jun 28, 2018 2:56 pm
Dear wwoodworks
One way would be to model the top in SketchUp and export as polyface mesh (plugin details below). When I tried just now I opened this DXF in Partworks 3D made it two sided and toolpathed it there. Someone may show you how to take this 3d.dxf into Aspire or vCarve Pro direct.
At first I considered a series of fluting toolpaths with a bullnose cutter. It works great on the face but more difficult in the rebate on the back side.
Sincerely and in good faith
Martin
Images
SketchUp Plugin
https://www.guitar-list.com/download-so ... dxf-or-stl
SketchUp Model
Partworks 3D Face Side
Partworks 3D Back Side
Martin Reid
Model of CNC Machine: Shopbot
Postby Adrian » Thu Jun 28, 2018 3:30 pm
You can import Sketchup files (2D and 3D) directly into VCarve and Aspire so you shouldn't need a 3rd party plugin.
Postby TReischl » Sat Jun 30, 2018 12:04 am
This is one of those things that is best created with plain old shop equipment.
The last time I did one of these IIRC, the drawer front is cut extra thick. The joinery is all done while it is still flat (that would be things like dovetails). Then the bandsaw roughs the curves in. Any rabbets can be cut using a router table and a rabbeting bit. If a slot is needed, some idea, just use a grooving bit with a large bearing.
Watching something like that slowly cut on a cnc router and then knowing you STILL have to sand the heck out of it doesn't make a lot of sense to me. Now, if you do not have a bandsaw...that is a horse of a different color.
Edit: Whenever I use the cnc I always remember the great old saying "Just because you CAN doesn't mean you SHOULD".
http://www.tedreischl.com
Low Profile CNC Router Vise
Return to Aspire - General
Users browsing this forum: Bing [Bot], gkas, Google [Bot], stanv77 and 32 guests
