Is there a way to make the background of this carving stand out more than it is? It's supposed to be an eagle in front of the flag and I don't think the flag pops out like I would like it to.
http://img.photobucket.com/albums/v697/ ... vui6li.jpg
Accentuate a model's background
- Vectric Staff
- Model of CNC Machine: Various
Re: Accentuate a model's background
Hey There!
The link you have uploaded doesn't work, could you upload the image direct to this forum?
Beki
Senior Application Engineer - Vectric Ltd.
When you go to the link, click the arrow to the next image, then the arrow to go back, and it will show up.
- Vectric Staff
Ah I can see it now thank you!
Well there are quite a few ways to accentuate the background flag, I'm sure there are many experienced modelers here who could tell you multiple ways of getting the results you desire.
But if I were to do this I would probably look at drawing closed vectors to represent every other stripe (see image as example) and then with these vectors I would use the Create Shape modeling tool and use an angled profile and limit the height, that way you create a bold border from the angle yet the shape is still flat, and set that to subtract. An example of the kind of shape i'm referring to is demo'd in this video I did a few years ago:
http://support.vectric.com/tutorials/V8 ... oon_2.html watch it at around 39.00. This should help you accentuate the stripes in the flag! alternatively you could just use a flat profile set to subtract too. Another option would be too look at sculpting into the flag (using the sculpting tool) and using a method where you subtract to accentuate the stripe line and then smooth and smudge back into it to create a smooth transition.
I hope this helps!
I hope this helps!
Beki
