Two Rail Sweep a tree
Postby garymkrieg » Mon Jun 18, 2018 11:24 pm
I have a 3d carving that has a tree that is cut to a depth of over 1/2". Rather than having straight cut on the sides it would be great is I could give it a more rounded profile using the two rail sweep. Unfortunately, I'm not even sure where to start with such an irregularly shaped item. Any ideas, attached is a file that will show you what it looks like. The tree in question is to the left, the bottom is beach and can be ignored.
Gary
Tree.pdf
(2.87 MiB) Downloaded 64 times
garymkrieg
Model of CNC Machine: None yet
Re: Two Rail Sweep a tree
Postby SteveNelson46 » Mon Jun 18, 2018 11:40 pm
Have you tried sculpting? Maybe adding a little base and draft. Then smoothing. The original pic is very low resolution so the finished quality will probably not be very good.
SteveNelson46
Postby highpockets » Tue Jun 19, 2018 12:20 am
Steve is faster than I am.... :D :D :D :D
Return to Aspire - General
Users browsing this forum: mtylerfl, RocketNozzle and 36 guests
