making 3.2mm slot with 3.0mm end mill?
kelderkold
Model of CNC Machine: home build
Post by kelderkold »
Hi I am new to this and I am making a slotcar track but my end mill i 3.00mm and I need the slot to be 3.2mm
I am routing on the line since the sections will not fit together if I route outside og inside the line.
So what is the tip to take an extra 0.1mm from each side at the end?
regards
Keld
ger21
Re: making 3.2mm slot with 3.0mm end mill?
Post by ger21 »
Offset the vectors 0.1 to each side and cut those.
kelderkold
Thx Gerry, just found out that it was possible :idea:
