Lathe software
Lathe software
Is anybody using Aspire to produce files for a lathe? Or is there some other software you can recommend that's as good as Aspire but specifically for lathes?
- SteveNelson46
Re: Lathe software
I have used Aspire many times to draw a profile and cut it out on the CNC then used it as a template for the duplicator on my lathe. I usually use plexiglass or acrylic for stability. I guess ideally one would have a duplicator lathe that accepts gcode and would cut the part directly but unless you have a business to justify the cost, not too many of us can afford that kind of equipment. On the other hand, if you had an indexer for your CNC...
Awhile back there was a discussion on how to profile a baseball bat using the molding toolpath. A search will probably turn up something.
EDIT: Here is the file that was posted. I don't remember who posted it.
- Bat-Molding TP.crv3d
- (178.5 KiB) Downloaded 197 times
- IslaWW
Re: Lathe software
Tim....
Wood or metal lathe?
Gary Campbell
GCnC Control
GCnC411 (at) gmail.com
GCnC Control
- TReischl
Re: Lathe software
Probably the biggest issue with trying to use Aspire to program a CNC lathe is the roughing routines. I have not seen anything in Aspire that would work. And yup, I can do it by drawing the paths, but that is not exactly very user friendly. Same thing with facing.
- Model of CNC Machine: home built shopbot clone. CNC lathe
Re: Lathe software
I use Dolfincadcam for my CNC lathe. A cnc lathe is a whole different animal than a cnc router. I don't think its as nice as Aspire but it's a different kind of software.
Don
Don
- IslaWW
Re: Lathe software
Centroid's Intercon for the lathe is very good for the lathe. Included with their hobby controller the Acorn.
Gary Campbell
GCnC Control
GCnC Control
Re: Lathe software
Thanks all, sorry I forgot to say it would be for a metalworking lathe. Gary - I was thinking of using the Centroid Acorn controller as mine is very clunky. Do you use it? It looks very good from what I've seen.
- IslaWW
Re: Lathe software
Tim...
Yes, very good. I converted a G0752 and added a QCTP. Liked it enough to build a router with an Acorn. On my 4th Acorn now.
I have vids on my YouTube page of them all
Gary Campbell
GCnC Control
GCnC Control
Re: Lathe software
Gary,
I am looking to get a cnc wood lathe, I have a ShopBot 48 by 96 alpha. Not sure if I should build a stand alone cnc lathe or get the ShopBot add on. What would be the cost to build a Acorn machine?
- IslaWW
Re: Lathe software
rmooreh wrote:Gary,
Best to contact me offline. Email gcnc411@gmail.com
Gary Campbell
GCnC Control
GCnC Control
