Can I do 3D renderings with Aspire?
I just acquired a used Multicam 1000 for which I need to buy either VCarve Pro or Aspire. Since I do lots of booth designs using SketchUp, I’m wondering if Aspire works for doing 3D renderings.
- mtylerfl
Re: Can I do 3D renderings with Aspire?
Not directly, but Aspire has an option to save a model as a POV-Ray Scene. The option only appears after you use the "Export model as STL", click the "Triangulate", then click the "Save Triangulation". At that point you can choose from three options to save the file as STL, OBJ or POV-Ray Scene.Jnarvarte wrote:I just acquired a used Multicam 1000 for which I need to buy either VCarve Pro or Aspire. Since I do lots of booth designs using SketchUp, I’m wondering if Aspire works for doing 3D renderings.
I played with this a few years ago. Downloaded the POVRay software (it's free, or was then anyway). Unfortunately, I never spent enough time with the software to figure out how to get a nice rendering of the POV-Ray Scenes I exported/saved out of Aspire. Maybe you can?
Could you develop, please?
I don't understand why you want to make a render in Aspire if you are designing in Sketchup.
Best regards
Didier
W7 - Aspire 8.517
Didier
W7 - Aspire 8.517
You won't get a rendering out of Aspire to the same quality as Sketchup. The problem is that as Aspire is pixel based you always get a rough "finish" to edges in the POV output.
