Help Please
vfauto
Model of CNC Machine: Legacy Artsian 72"
Help Please
Post by vfauto »
Can someone tell me how to raise this complete model up so that the bottom is .1875 high before the dome starts carving.
https://drive.google.com/file/d/1_BPQ3g ... sp=sharing
Thank You
Frank
Re: Help Please
Post by highpockets »
Frank,
Are you referring to the grape cluster? You want it to be .1875 proud of the dome top?
vfauto
Re: Help Please
Post by vfauto »
highpockets wrote:Frank,
No I want the dome and the grapes to raise up so there is an edge at the base of the dome.
Thank You
Frank
Re: Help Please
Got it...
You're working with a .75 thick piece of material.
.75 - .1875 (desired thickness below the bottom of the dome) = .5625 left for dome height and grape cluster height.
I added a Zero Plane component.
I set the height of the dome component to .25 and 0 base height leaving .3125 for the height of the grape cluster.
I set the grape cluster component height to .3125 and 0 base height
In Material Setup under Model Position in Material I set the Gap Below Model to .1875
vfauto
Re: Help Please
Post by vfauto »
highpockets wrote:Got it...
Not sure I understand zero plane but when I get back to software I will play with it.
Thank You
Frank
Re: Help Please
vfauto
Re: Help Please
Post by vfauto »
highpockets wrote:Watch this tutorial.
http://support.vectric.com/tutorials/V9 ... &time=1207
I will tonight , can you send me the modified file so I can look at it too?
Thank You
Frank
Re: Help Please
PM sent.
vfauto
Re: Help Please
Post by vfauto »
PM sent.
Got the file thanks
Thank You
Frank
