Modeling help
- Model of CNC Machine: FLA Saturn 4x4 / 7W & 60W lasers
Modeling help
Can someone tell me if it possible to model this in Aspire. New at modeling so could use some help. I have created this before (but not as a model), but I had to rotate the part to accomplish both the side and top down profile. Would like to be able to machine without having to rotate as re positioning correctly was an issue. Thanks
- CANOE.crv3d
- (1.66 MiB) Downloaded 70 times
Dave
https://lakesedgewoodcraft.com/
- highpockets
Re: Modeling help
Don't see how you're going to get the undercut without flipping the material weather you model it or use the Moulding toolpath.
- highpockets
Re: Modeling help
If you don't mind finishing the bottom curve on a sander you can use the moulding toolpath to get the top part.
Re: Modeling help
Thanks John. I played with the moulding toolpath, but couldn't figure it out. Can you explain in simple terms how you accomplished that, please?
Attached are my results in pink foam. Was hoping to get a sharper point on the front and rear.
Dave
- highpockets
Re: Modeling help
I'd wear out my fingers see the attached.
- CANOE-1.crv3d
- (920 KiB) Downloaded 94 times
Re: Modeling help
Thank you John for the file. It makes more sense now that I can see it toolpathed. I wasn't even close with my moulding try..
Dave
Dave
Dave
- highpockets
Re: Modeling help
Happy to help.
The great thing about VCP & Aspire are there are lots of ways to skin a cat. I'm sure others will show you much better ways. This was just a quick down and dirty try. Some additional refinements would help.
- mezalick
Re: Modeling help
highpockets wrote:Happy to help.
Nice approach John,,,
Just to expand upon your design I chose to use the entire top vector of the canoe as the molding profile.
The the pocket and cutout as you have.
Three toolpaths...
Just another way...poor cat..
Michael
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
- highpockets
Re: Modeling help
Thanks Michael (and John). Always good when you can eliminate a toolpath to accomplish something.
Dave
