I have an STL model of a skull that I scaled down in size to be about 5" x 5" x 7" using the free version of Netfabb. Resaved a new STL. I then took this resized skull into Windows 3D Builder to slice it into 8 pieces so I can try the 2-sided machining on it. I now have 8 separate STL from 3D builder, all scaled to about 1" thick. So the size remains about the same as the original resized model if I were to stack the slices one on top of the other.
The problem I'm now having is when I try to bring any of the slices into Aspire, the model dimensions are not what they were in the other 2 programs (about 5" x 5" x 7") or 1" thick per slice. As you can see from the attachment, one of the slices upon import reads 200.4"x X 84.8"y X 18.8"z ???
If I try to resize in Aspire, as there are 8 separate files, the resizing would not be consistent across all files and the slices will not glue up right.
What do I have to do for Aspire to ensure that the dimensions are the same as in the STL file?
Thanks for any ideas anyone may have.
Maintining Scale on STL Import
- mfirlott
- Model of CNC Machine: Stinger 1 (2014)
(Mitch)
CAMaster Stinger I
Vectric Aspire
Epilog 45watt Helix Laser
CAMaster Stinger I
Vectric Aspire
Re: Maintining Scale on STL Import
Can't help with the sizing issues but just wondering why you didn't just import it straight into Aspire & then resize & slice it in Aspire
- mtylerfl
You likely have Netfabb (or 3D Builder) set to export in mm instead of inches. Click the Scale mm/inches button and type in your desired value(s).
For more info on resize conversion from mm to inches (or reverse), see the following:
http://support.vectric.com/aspire-quest ... asurements
or
or
- Model of CNC Machine: Camaster Stinger II
If you pick a value on one of the axis and type in the value what you want with the axis locked ....the system will scale the STL to that dimension
- mfirlott
Thanks...I will try these suggestions.
Did not do directly in Aspire as model has too many undercuts and it looked terrible in Aspire. That's why I sliced in other software.
(Mitch)
CAMaster Stinger I
Vectric Aspire
CAMaster Stinger I
Vectric Aspire
- mtylerfl
YupPete Cyr wrote:If you pick a value on one of the axis and type in the value what you want with the axis locked ....the system will scale the STL to that dimension
- mfirlott
OK...got it. Thanks for pointing me in the right direction.
As Netfabb is the free version, I cannot change any export settings BUT I did make sure in Aspire model orientation to lock the axis and chose one axis, the "x" in my case, and chose a factor, "x/30=" in my case and did this to all slices and now I believe it'll work just fine.
Thanks everyone for pointing me in the right direction.
(Mitch)
CAMaster Stinger I
Vectric Aspire
CAMaster Stinger I
Vectric Aspire
