JobSheet Creation Problem
- Model of CNC Machine: CAMMaster Stinger II
Hi there, trying to create a job sheet in a two sided file this morning and getting the attached error message. Looks like it is related to the "flip" function in the jobsheet? Is there a new gadget needed for Version 9, didn't see one on the gadget site but may have missed it. Thanks.
Re: JobSheet Creation Problem
Looks like you're running a modified version as the pathname in that error message is where the Setup Sheet runs from if its modified. The base version is in the Gadgets folder of the Application Data folder (open from the Aspire file menu).
If you delete the modified version then the default version should be picked up instead as far as I know.
Thanks, I deleted the gadgets folder in that directory, restarted Aspire and it worked. Thanks!
Not sure how I ended up pointed at this folder but appreciate the quick response and fix!
