AutoCAD 2018 dwg
- Model of CNC Machine: eZrouter
AutoCAD 2018 dwg
Does Version 9 allow importing of AutoCAD 2018 dwg files or will they have to be backsaved?
- IslaWW
Re: AutoCAD 2018 dwg
Export from AutoCAD
The simple answer is to just save as Version 12 .dxf.
Version 12 strips out a lot of the stuff from newer versions that can cause problems, and it also converts splines into polylines (made up of straight segments).
~Gerry G.
~Gerry G.
Gary Campbell
GCnC Control
GCnC411 (at) gmail.com
GCnC Control
I just tested it, and yes, it does.
But I always use v12 .dxf, as Gary relayed.
Does anyone know if the import of the dxf or dwg is the same as an import of an STL? STL is converted to bitmap height image.
I believe that this post is referring to 2D drawings.
for 3D, all 3D models are converted into a "pixel based height map" type model. That's the way Aspire works. It's not a 3D CAD program.
