I am stumped.
I have a board with 1/2" depth of material.
I want to remove .25" of material surrounding the text.
A V Carve tool path makes sense, but I can't select an endmill, the software is saying NO, it V-Carve, therefore dumb user, you use a V-Carve Bit... Seems reasonable.
Rectangle
Matt's Collectibles
Remove material surrounding text.
ONLY Letters remain at .5" -- the depth of the board
Wish to remove material surrounding text.
Unable to Complete Basic task.
I've tried to select the boundary of the rectangle and the text...do I put the text in another boundary?
I am easily able to bring the letters down .25", but not able to remove material surrounding text.
Your help is most appreciated.
Simple toolpath question for everyone but some modeling software...
- Model of CNC Machine: DWC2440,TaigCNCMill,Dellta3003d, Epilog
Re: Simple toolpath question for everyone but some modeling software...
Someone always has to try and do the opposite of the norm. Sorry. I thought I had it solved and found my vcarve bits, but it did not work.
I eliminated all my trial tool paths. The modeling created of the letters is what I wanted.
- Matt's Collectibles.crv3d
- (511.5 KiB) Downloaded 67 times
- dealguy11
Not sure I completely understand you, but looking at your file, if you select both the text AND the rectangle at the same time, I think you can accomplish what you want. A carving toolpath is definitely not the right tool for this.
There are a couple of ways to proceed.
1. If you want the look of a vcarve (see below) then use a v-carve toolpath with both the rectangle and letters selected. Check the "Flat Depth" checkbox, and set a flat depth of .25". It is also probably best to check "Use Flat Area Clearance Tool" and select some kind of end-mill to hog out the flat areas so that the v-carve bit won't have to remove as much material. It will look something like this (first picture is with a 90-degree v-bit and the second is a 60-degree v-bit) 2. You can also use a pocketing toolpath if you want straight sides on the letters. Similar process, but use end mills instead of a v-cutter. If I use a 1/8" end mill with a 1/4" clearance tool, it looks something like this (Note that there are run-together letters because they are too small for the 1/8 bit to clean up between the letters):
Steve Godding
- Model of CNC Machine: Home built wooden machine - Mach3/Aspire
Another tool choice would be a 1-flute engraving cutter ie: 45° with a 0.020 or 0.030 flat at the tip. These cutters produce stunning results. Search for 'Stacked text' or Text on Text' for more info.dealguy11 wrote:Not sure I completely understand you, but looking at your file, if you select both the text AND the rectangle at the same time, I think you can accomplish what you want. A carving toolpath is definitely not the right tool for this.
