I hope this makes sense, I would like to create a toolpath the that starts at Z zero and progressively cut the depth to about .35 inch. Not sure how to accomplish this, hope someone can steer me in right direction.
Thanks in advnace
Create a pocket with shallow to deeper depth
- IslaWW
Re: Create a pocket with shallow to deeper depth
Multiple parallel vectors using the "Fluting Toolpath" There are numerous example you should be able to search for
Gary Campbell
GCnC Control
GCnC411 (at) gmail.com
GCnC Control
Depending ow what otehr operations are required, but a shallow shape like this could be easily done by tilting the material.
Paul Rowntree
Thanks I will take a look on Fluting ToolPath
- dealguy11
Can also be done with the moulding toolpath
Steve Godding
