Would someone please explain the difference in making a node a bezier vs. smoothing the node? When is one more appropriate then the other? I would really appreciate an explanation! Thanks!
Sylvan
Node Editing/Bezier and Smoothing
- Model of CNC Machine: Camaster Stinger II
Re: Node Editing/Bezier and Smoothing
A two or more smoothing nodes makes a Bezier Line. They are Bezier lines/curves ..not Bezier nodes.
- IslaWW
Sylvan...
I am sure you can figure the Bezier out by playing with the handles. To figure out smoothing try this:
Make a rectangle
Change all lines to Bezier
hover over each corner and play with the handles both before and after you press "S" over the node
Smoothing keeps the handles the same length and equidistant from the angular centerline of the approaches. "in smooth" lets them be what you need them to be
Make a rectangle
Gary Campbell
GCnC Control
GCnC411 (at) gmail.com
GCnC Control
- sylvan356
- Model of CNC Machine: CAMaster Stinger 1 w/Rotary, Aspire 12
Thanks for the replies. They make perfect sense!
Sylvan
Sylvan
