Move to Back?
Move to Back?
I am working with Aspire 8.5. I am trying to layout different 3d components and use the "move to back" command, but it doesn't work. Has anyone had problems with this?
- mtylerfl
Re: Move to Back?
All the models you want to change the 2D grayscale visible order of must be on the same layer for the Move to Back (etc.) function(s) to work.
Once you have them on the same layer, it will work perfectly.
Re: Move to Back?
You can also use layers order to control overlapping of 2D previews. But as "move to back" it will only act on 2D previews.
You mentioned 3d components. These ones are controlled by the component manager.
Read carefully the "Layer Management" and "Component Manager" chapters of the manual.
Best regards
Didier
W7 - Aspire 8.517
Didier
W7 - Aspire 8.517
Re: Move to Back?
Thanks for your answers, I tried it and yes that was my issue. I forgot to place things in layers. Thanks so much.
