Maybe a dumb question
But
When using the claranace tool option in the v-bit
can you use any tool (within reason)
like a ball nose
ty
andy
v-bit with clearance tool
Re: v-bit with clearance tool
It seems you can select a ball nose. Just try it and run the simulation.
But using anything else than an end mill as a flat area clearance tool doesn't make sense for me.
Why would you use another type of tool?
Best regards
Didier
W7 - Aspire 8.517
Didier
W7 - Aspire 8.517
Can you use a ballnose as a clearance tool with a Vcarve toolpath? Yes
Would it be a good idea? Not really since it won't save much time over just letting the Vbit do all the work.
