Is it possible to import a 3D model .stl file found on Thingiverse.com into Aspire V9? I attempted to import a model to trim a small edge off the model so it would fit in the printing envelope of my 3D printer. Everything seems to progress as normal until I click ok on the Orientate 3D Model page.
Dan
Import Thingiverse stl file into Aspire V9 Problem
Re: Import Thingiverse stl file into Aspire V9 Problem
And then what happens?Everything seems to progress as normal until I click ok on the Orientate 3D Model page.
Unless it's a very simple shape with no undercuts, side holes etc then Aspire is the wrong program to edit it in as those features won't be preserved for 3D printing.
- Model of CNC Machine: 4x4 DIY Router
Thanks for all the responses.
In response to "what happens" --
When the model is first imported it appears as a normal 3D model on the Orientate 3D Model page. I have attached a screen shot of the modeling page that opens after clicking ok on the Orientate 3D Model page. What appears is a flat rectangle that looks like a thin piece of material. I thought if I would scroll in and out that I see something more but there is nothing else to be seen.
Aspire not the right application --
Thanks for the reply about Aspire not being the best application to use to trim the part. Do you have a recommendation for a better application to use to trim/modify a3D model?
I really appreciate the feedback.
Dan
Dan
Check the scale to make sure it's not just really tiny. Click the Center Model in case it's off screen somewhere.
The two images show what I mean about Aspire and 3D. It's designed for 3 axis CNC machines that can't create models in the same way as a 3D printer can so if you use it to edit then you're going to lose information on some models. It can certainly be used for a lot of 3D printed stuff but it depends on what it is.
For 3D printing (I have a Zortrax M200) I use Aspire, OpenSCAD, Sketchup and other software depending on what I'm making.
Wow! I see what you mean about what happens.
Thanks for the feedback and the list of applications.
Dan
Dan
