v9.013
Re: v9.013
Version 9.013
Bug Fixes
General & Drawing
Fix filleting tolerancing issue in inch jobs.
Fix a PDF export scaling issue where the size was off by a very tiny amount.
Fix some document variables pasting the content of the copy/paste buffer.
Fix linking X and Y sizes on the scaling form in some cases.
Update the 2D view when importing a Machinist project.
Ensure the 2D view is up-to-date when popping up the notes dialog on startup.
Fix Job Setup form resetting the Z origin
Modeling
Fix a case where the model was not placed within the material block correctly.
Toolpaths & Simulation
Fix number of passing resetting on recalculating a profile toolpath when the cut depth is set to a variable.
Fix applying a pocketing offset to some circles.
Fix Moulding Toolpath corner rounding.
Fix Array Copy Toolpath not optimising for tool changes correctly in some cases.
Fix Array Copy Toolpath recalculate
Bug Fixes
General & Drawing
Modeling
- Model of CNC Machine: CNC Pilot Pro 5050
Re: v9.013
Thanks for the information Randall. Other than checking for updates using the Help Menu in the software is there a place online or a way to get emails sent to us for the Upgrades and Bug Fixes for the Revisions of Verision 9 Aspire ? This is such a great Forum and it is helping me a lot. Thanks for any information and have a great day/night.
Cheers - Fred Grover
- Model of CNC Machine: Probotix Nebula
Re: v9.013
Thanks for posting.
Re: v9.013
Aspire will tell you when there's an update, in the upper right corner of the screen. And it's a link, so you just have to click it to start the update.Other than checking for updates using the Help Menu in the software is there a place online or a way to get emails sent to us for the Upgrades and Bug Fixes for the Revisions of Verision 9 Aspire ?
Re: v9.013
Thank you ger21 for the quick reply. Much appreciated. Hve a great day/night.
Re: v9.013
I still have a dogbone fillet challenge for you clever Aspire programmers to work on. On outside (larger than 90 degree) corners the dogbone fillet greatly overdraws what it needs to.
In the case I show in the file attached I want to make a small pocket for a 1/4-20 hex nut to drop into. The blue line is the nut outline. The black line is that same outline with 1/16" radius dogbone fillets applied to each corner. The red outline is what would have been the most efficient (minimum) amount of dogbone to apply. I had to manually free and move and trim/extend each dogbone to create the red outline. Seems as though this expensive software should be able to handle it right on its own.
4D
4D
- Hex Nut Dogbone Example.crv3d
- (44 KiB) Downloaded 106 times
- larrybadgett
- Model of CNC Machine: ShopSabre
Re: v9.013
Where's the patch file for download? All that is on the portal is V9013 total install. Really don't care to do that!
Re: v9.013
If the machine is on the net it's downloaded from the Help menu or by clicking the notification in the top right. For offline PC's the updates are here - http://www.vectric.com/support/program-updates.html - but 9.013 doesn't appear to be there yet.
You can copy the patch file from the Aspire program files folder from a PC that has updated across the net though.
Re: v9.013
Well Adrian beat me to it as I was just going to say the same thing to Larry Badgett on that. I just updated yesterday and with the link Adrian Provided for the Program Updates I hope to see Vectric get on the ball and add those to keep it more up to date. Thanks for sharing Adrian and everyone have a great day/night.
Cheers - Fred.
Cheers - Fred.
- larrybadgett
Re: v9.013
Thanks Adrian I'd forgotten about getting it out off the program folder!
Re: v9.013
I only see V9.012 update on that page. I should read more and speak less
Bob
Bob
