Pattern request
- Model of CNC Machine: TS1325
Pattern request
Kindly looking for this pattern or ways to do something similar.
Any help is greatly appreciated.
Many thanks in advance
Jane.
- highpockets
Re: Pattern request
This tutorial will help with the weave pattern. http://support.vectric.com/tutorials/V9 ... ideo_id=67
Re: Pattern request
You don't need to model it if you have a veining bit (roundover bit with a sharp tip). Layout the bottom lines of the pattern and do a profile cut ON the line with the veining bit. If I had more time this morning I'd make up a sample.
https://routercutter.co.uk/point-cutting-round-over
Re: Pattern request
Thank you for the kind response and ideas. I do not have this kind of bit can i use a ballnose or 90degree V-bit?
Jane
Jane
- highpockets
Re: Pattern request
Not quite there, I missed the little gaps, but you get the idea. This was using the extrude weave.
Re: Pattern request
It would be worth it to invest in the veining bit. It will cut much faster than doing it as a 3D model job.
4D
4D
- Weave with veining bit.crv3d
- (471.5 KiB) Downloaded 112 times
- highpockets
Re: Pattern request
You nailed it as usual.....4DThinker wrote:It would be worth it to invest in the veining bit. It will cut much faster than doing it as a 3D model job.
- Model of CNC Machine: CNC Pilot Pro 5050
Re: Pattern request
Thanks for the link to that Bit 4DThinker and the file for it. Do you have the exact Router Bit Part # from Whiteside so I can get it here in the USA ? Thanks for what you do here to help others.
Cheers - Fred.
Cheers - Fred.
Re: Pattern request
Whiteside: https://www.whitesiderouterbits.com/col ... -roundover
They have them with a few different radius dimensions. I don't know what scale you need that pattern made, so you can choose from the selection on that linked page.
4D
4D
Re: Pattern request
Thank you so much 4DThinker,
Am definitely going to invest on the bit. thank you.
Kind regards
Jane.
Kind regards
Jane.
