i was more work than i thought but needed to use metal keyhole plates for wall plaques
made a template with aspire for them
wow so much easier than had cutting
keyhole metal mounting plate
Re: keyhole metal mounting plate
my apologies for not posting the 3d file
I did not use the toolpath gadget. It only creates the keyhole only. This is for the metal plate you screw down and the pocket for the screw
rockler #28837
It cuts the indent for the plate to be flush as well as room for the screw head to insert and pass through
andy
rockler #28837
andy
- keyhole hanger.crv3d
- as all make sure you cut a trial before using. I used a 1/8 spiral straight bit
- (174.5 KiB) Downloaded 121 times
