Newbie:
so I'm trying to make an inscription. I want to do an inlay. the female part is easy, but doing the male part the tool path wipes out some of the letters..........what can I do to get the complete inscription? I've uploaded the file so you can tell me where I went wrong or how to correct.......the file was too big so I had to wipe out some of the saying but you can play with it and see what I see. Thanks in advance
male inlay ***toolpath wipes out letters***
- Model of CNC Machine: piranha
- Charlotte male inlay.crv
- (1.57 MiB) Downloaded 112 times
Re: male inlay ***toolpath wipes out letters***
Because it's a script font there are lots of overlaps. The VCarve toolpath will handle that if you're carving inside the letters but not outside. You'll need to convert the text to curves and remove the overlaps to join the multiple shapes into one.
- Vectric Staff
- Model of CNC Machine: 6040 Desktop CNC
here is a link to the part of a training video that goes into detail about editing script text to accomplish what you are after,
http://support.vectric.com/tutorials/V9 ... &time=1197
BINGO ! ! ! THAT DID IT ! ! !
THANK YOU VERY MUCH ! !
[I've been banging my head on this one for a while.]
side note: the video doesn't show that after you convert the text to curves then weld them, you have to group them in order to get them selected in the tool path.
Thanks again
Thanks again
- Model of CNC Machine: K2CNC 2514 & V90
Simple answer is to just put a .001 off set vector (line) around your text. Then only select the outside Vector (line), Inside circles and your square, recalculate- cut. I would also use a .0350 end mill as an clearing tool along with a Chisel point 60 degree V. Takes a little longer, but looks real nice when done.
- dealguy11
Not sure about that last statement regarding grouping the vectors to get them into a toolpath. I've never run into a case where you HAD to group vectors to create a toolpath. It may be a good thing to put them all into the same layer if you're using vector selection for the toolpaths. Otherwise, you just select all the vectors for the toolpath and then create it.
Steve Godding
