Hi Everybody,
Just a quick topic that I feel sure the experts will quickly solve.
I have noticed that when I dimension a drawing in Vectric .... when printed out the diamension lines and text are very pale and quite difficult to read.
I have experimented with various fonts with little success
Any solution?
Diamension Lines
Re: Diamension Lines
Printing directly from Aspire or exporting and printing?
- Model of CNC Machine: Heiz High Z Machine German manufacture
Hi Adrian,
At the moment I am printing directly from Aspire
Soapy
Soapy
If you make sure the Place Dimensions On Layer box is checked you can change the colour of the layer that the dimensions are on using the layers tab or dropdown to make it clearer when printing.
Thanks.... will try in a moment or two
Thanks once again.... I had the dimensions on a separate layer.... changed this layer to a sort of dark blue and it is now quite clear and more legible.
I have not experimented yet but will the dimension layer remember my selection or do I need to do this each time
Great forum
Great forum
Don't know to be honest. I always use the default colours so you'll have to experiment. I expect it will reset each time unless the layer already exists in the job.
