I had my first attempt at toolpath tiling today. I thought everything seemed to go well until I got to the second tile and was starting my profile path to actually cut out parts.
I am building some shelves and I am using a full sheet of plywood. My tiles are 41" feeding through the Y direction. I have already cut tile 1 with all of the toolpaths and had no issues. I cut some dado grooves and tongues, screw holes and shelf pin holes on tile 2 without issue. I think the problem is related to the toolpaths that are shared between the two tiles. I am using Mach 3 to run my CNC.
When I load the toolpath, it immediately loads to a line well below the usual line 1. The status says "Zero radius arc. Block=N270G2X1.7500Y23.500010.2500J0.2500" pic attached. I thought maybe the file was corrupted and tried saving it again but had the same result. For profile cuts, I generally have a rough cut and also a final cut using a diamond bit. I had the same issue attempting to run both toolpaths.
Hopefully the issue will be an obvious one. thanks
issue with toolpath tiling
Re: issue with toolpath tiling
Check the vectors at that position (X 1.75, Y 23.5) as I've seen posts in the past about that error and it's usually because of an error with the vectors themselves, crossovers, loops etc.
- Model of CNC Machine: CNC Routerparts Pro 4848 Piranha Fx
Adrian,Adrian wrote:Check the vectors at that position (X 1.75, Y 23.5) as I've seen posts in the past about that error and it's usually because of an error with the vectors themselves, crossovers, loops etc.
I checked the file but I don't see anything out of the ordinary. There are no overlapping vectors or anything. It looks like the sharp corner of the bottom left end of my cabinet.
Would it help to upload the file or would the tiles still show?
- Leo
yes upload your file, but not any copyrighted contents
The file size is 3583kb and apparently, I am restricted to 3Mb.Leo wrote:yes upload your file, but not any copyrighted contents
Post a few lines of code before line 270.
N130 (End Mill {0.5 inch} Diamond cut)ger21 wrote:Post a few lines of code before line 270.
N140G00G43Z0.8000H1
N150S18000M03
N160(Toolpath:- Final Cut)
N170()
N180G94
N190X0.0000Y0.0000F190.0
N200G00X1.5000Y-0.0010Z0.8000
N210G1X1.5000Y-0.0010Z-0.7400F100.0
N220G1X1.5000Y16.1094Z-0.7400F190.0
N230G1X1.5000Y16.1094Z-0.6400
N240G1X1.5000Y16.7844Z-0.6400
N250G1X1.5000Y16.7844Z-0.7400F100.0
N260G1X1.5000Y23.2500Z-0.7400F190.0
N270G2X1.7500Y23.5000I0.2500J0.2500
For those interested, I sent the files to Vectric and after testing, they responded that it was an issue within the software. A fix will be in the next update. thanks Vectric!
