After you send a post a realize that you made a mistake can you delete that post and fix your mistake and the resend it
Glenn
Deleting post
- Model of CNC Machine: Probiotix meteor 26x50
- dealguy11
Re: Deleting post
You can edit the original post if you do it quickly after posting. You can also delete it...there is a little "X" in the top of the box for deleting (but only for your posts). I've edited this post twice. Was going to show a snip of the controls for editing, but they won't stay active while I snip!
Re: Deleting post
If you're using the Microsoft snipping tool you need to use the Delay feature to capture bits like that.dealguy11 wrote:You can edit the original post if you do it quickly after posting. You can also delete it...there is a little "X" in the top of the box for deleting (but only for your posts). I've edited this post twice. Was going to show a snip of the controls for editing, but they won't stay active while I snip!
