I have an stl file but i only want to machine the scallop design into some MDF is there a way to machine the scallop only in the MDF then cut out the profile? when I import it it seems to want to machine the entire surface of the MDF will be .250 thick I have included the pdf
Thanks all
help with stl
- Model of CNC Machine: 3252
help with stl
- 6in Scallop-NEW-V6.pdf
- (152.2 KiB) Downloaded 121 times
- highpockets
Re: help with stl
Add a bounding box around the component then select Selected Vector under Machining Limit Boundary in the roughing/finishing toolpaths.
Re: help with stl
Besides the STL file do you have access to the vectors used to create the scallops? If so bring them in Aspire and limit your 3D cuts to the areas defined by those vectors.
Re: help with stl
I dont have access to the file Im hoping i can get someone to separate the stl when i create a bounding box I just get an error no suitable vectors, when I use the crate vectors it only does the profile not the scallops.
Thanks all
Thanks all
Re: help with stl
You have posted the PDF file for people to view, you can import that into the software & then trace the scallop vectors
If you don't have a lot of experience drawing/tracing then this would be a good project to practise with as it's pretty simple
- highpockets
Re: help with stl
Yes highpockets thats exactly what Im looking for
- highpockets
Re: help with stl
Steve, you've got everything you need to create this. I used the pdf file you posted.
Import the pdf
Select just one scallop, I used the right scallop.
Copy the selected vectors to a new layer and hide the Import layer.
Delete the unwanted horizontal lines.
The arch and vertical line or OK so nothing to do there right now.
Now the shell(?) needs some help it's comprised of short open vectors. You need to create closed vectors for each peddle(?) of the shell. This is where taking Martin's suggestion and learn Join tool and Node Editing is going to really help.
Once you have the peddles joined into 5 separated closed vectors, select the 5 peddles and arch and using the Array Copy tool you can make as many copies as you'd like.
Mirror the vertical line to the other side of the arches and draw a horizontal line at the bottom to connect the bottom of the vertical lines.
Selected all the arches, vertical lines and horizontal bottom line and create a closed vector using the Join tools.
Done.... Setup toolpaths as desired.
Hope this helps.
Import the pdf
Hope this helps.
