what am I doing wrong
Postby oldlogtrucker » Thu Nov 02, 2017 12:38 am
I am trying to make a simple plaque frame with a sloped border. The corners are not looking good. How do I fix them?
Thanks Kathy
plaque frame.crv3d
(70 KiB) Downloaded 48 times
Camaster StingerII - FTC, Vac Table - Aspire
Embroidery - WingsXP
oldlogtrucker
Model of CNC Machine: Cam Master StingerII
Re: what am I doing wrong
Postby Leo » Thu Nov 02, 2017 1:43 am
Did this once before but I cannot remember how to do it again.
There is a selection process then a box to select something like - make all corners the same - or something like that.
There IS a fix.
It's easy ------ when you know how.
www.leosworkshop.com
Leo
Postby oldlogtrucker » Thu Nov 02, 2017 3:40 am
Thanks Leo, Now to figure out what to do to fix it
Kathy
oldlogtrucker
Postby mezalick » Thu Nov 02, 2017 9:36 am
Kathy,
Please see attached picture.
Here are a few things to do.
In the two rail sweep options , choose the " Fill center of inner closed vector".
That way you'll only need one component.
Two, after selecting the two rails and the profile, click on the outer rail where to place the profile.
In this case I've click on each corner and then adjusted the inner "node" of the shape to align with the inner corner..
I hope this helps.
Michael
Michael Mezalick
https://carveddetails.com/catalog-book/
mm@mezalick.com
mezalick
Postby 4DThinker » Thu Nov 02, 2017 9:45 am
You don't need to model the plaque just to be able to bevel the edge. I looked at your file and deleted the models. I created a section view of the beveled edge, and used the moulding toolpath and an inside rectangle to wrap it around the plaque.
4D
plaque frame 4D.crv3d
(52.5 KiB) Downloaded 39 times
4DThinker
Postby mezalick » Thu Nov 02, 2017 11:15 am
Thanks 4D, I forgot about the Molding Toolpath...A much better way of doing this...
Michael
Michael Mezalick
mm@mezalick.com
mezalick
Postby oldlogtrucker » Thu Nov 02, 2017 2:52 pm
Thank you guys, this really should get me going. I am going to try to devote a couple hours a day to this program this winter, maybe I can get a better grip on things.
Thank you again
Kathy
oldlogtrucker
Return to Aspire - General
Users browsing this forum: mtylerfl and 32 guests
