2 sided machining not going full depth
Postby Wayne Locke » Mon Oct 30, 2017 7:58 pm
I am about to ram my head through he computer screen. What am I missing? I have a 2 sided chair seat which is 1.75" thick. The model looks great on both sides but the tool path will not go to the bottom. The z zero is to the center.
Wayne Locke
Re: 2 sided machining not going full depth
Postby BernieNUFC » Mon Oct 30, 2017 9:00 pm
I dont have aspire but i had not a too dissimilar issue in my post here, check Rebecca's reply, sorry if its nowt like your issue :-)
viewtopic.php?f=2&t=27835&p=201712#p201712
VCarve Pro v9.012
High-Zs 720- Kress 1050 router ( CNC-Step DE version)
BernieNUFC
Model of CNC Machine: High-Z S-720
Postby garylmast » Mon Oct 30, 2017 9:42 pm
If you import a 3D model, determine how much you want to undercut and add that positive number into the zero plane position in the model. If you don't have a zero plane add one and under properties put it as a negative height. Offset the toolpath the radius of the mills. Gary
garylmast
Return to Aspire - General
Users browsing this forum: Pete Cyr and 13 guests
