Ramping
Ramping
Postby phill05 » Wed Oct 25, 2017 10:13 am
Say you are doing a internal profile cut on a circle and select "add ramps to tool path" then Spiral is there anyway you can change the speed of the ramp down.
What I found is I had quite a few 5 mm and 16 mm holes to cut rather than using a peck drill sequence I prefer to end mill them out, the Spiral ramp is ideal on the 5 mm ones but takes a long time on the 16 mm ones so was looking if it is possible to increase the speed of Spiral for larger diameters a little.
Phill
phill05
Model of CNC Machine: Hybrid re-build
Re: Ramping
Postby Timvmax » Wed Oct 25, 2017 12:25 pm
Have you tried using a Circular Lead instead? You can then play with the Radius and lead length.
Timvmax
Re: Ramping
Postby Adrian » Wed Oct 25, 2017 12:27 pm
A ramp is always going to be a mixture of Z and XY moves so it will be constrained by the movement of the slowest axis. If you increase the plunge rate that should speed up the ramp.
Re: Ramping
Postby phill05 » Wed Oct 25, 2017 1:28 pm
Adrian wrote:A ramp is always going to be a mixture of Z and XY moves so it will be constrained by the movement of the slowest axis. If you increase the plunge rate that should speed up the ramp.
Thanks Adrian spot on,
I have the Z axis with a very slow down feed for cutting stone, I did not think of that it works a treat, Spiral works better for me than Radius & lead length no chance of harsh dig in's.
Phill
phill05
Return to Aspire - General
Users browsing this forum: No registered users and 24 guests
