best computer
best computer
Postby johnwn » Wed Oct 18, 2017 10:55 pm
I have to buy a more powerfull computer that will keep up with a Mach 3 tool path. my existing tower runs out off data. can anyone recommend a good one? Windows 10 seems to be installed on all the new computers. does this work fine? I no mine is 64 bit but old. Thanks
johnwn
Model of CNC Machine: homebuilt
Re: best computer
Postby martin54 » Thu Oct 19, 2017 12:09 am
What spec is your old computer ? You shouldn't really be having a problem with mach3 files, they don't require a particularly high spec machine :lol: :lol:
Are you sure your not using the demo version of mach3 which will only read 500 lines of code.
Re: best computer
Postby ger21 » Thu Oct 19, 2017 1:06 am
Sounds like a connection issue with your motion controller.
I'm running Mach3 on a 1Ghz Pentium III, and don't have any problems with it.
Gerry
ger21
Re: best computer
Postby johnwn » Thu Oct 19, 2017 2:33 am
older and refurbished and had to put in a larger video card. windows 7 with 4 ram. every so often cnc stop with message that smooth stepper ran out of data. mach 3 is full license and tried different lines look ahead settings and hertz settings. thanks for helping!
johnwn
Re: best computer
Postby ger21 » Thu Oct 19, 2017 3:13 am
That's a Smoothstepper issue, not a PC issue. A new PC won't likely help.
You might want to ask on the Warp9 forum, and see what they have to say.
Gerry
ger21
Re: best computer
Postby plcamp » Thu Oct 19, 2017 1:12 pm
Your computer is more than sufficient to run Mach3. Unplug all connections and re-seat them to make sure you have good electrical contact. If your problem persists follow ger21's suggestion and contact the manufacturer.
plcamp
Model of CNC Machine: Home built wooden machine - Mach3/Aspire
Re: best computer
Postby TReischl » Thu Oct 19, 2017 2:17 pm
definitely a smooth stepper issue.
http://www.tedreischl.com
Low Profile CNC Router Vise
Re: best computer
Postby johnwn » Fri Oct 20, 2017 8:22 pm
ok i will try and thanks everyone! :)
johnwn
Return to Aspire - General
Users browsing this forum: Barry Anderson, Plumblost and 21 guests
