Diamond drag bit setup
Postby robertf » Tue Oct 17, 2017 3:41 pm
Just bought a diamond drag bit, need help on how to put it in tool list & how to set up the tool path
Any help out there?
robertf
Re: Diamond drag bit setup
Postby FixitMike » Tue Oct 17, 2017 6:08 pm
Use the Quick Engraving toolpath. I set the depth/pressure at 25% to 50% of the total travel available in the tool. However, I've done some testing, and on acryllic, it makes very little difference. Fill stepover does affect the result. I use .005" to .012" depending upon the size of the picture.
In the Tool Database Tool list, you find Engraving way down the list. There is a diamond drag tool listed. The Geometry and Cutting Parameters entries affect only the preview, they do not change what the machine does. (See the toolpath description in Help, Help Contents.) Spindle speed should of course be zero (Turn off or unplug the router.).
I find the Quick Engraving toolpath preview to be very poor. If I want to get an idea of what the result will look like, I use a VCarve toolpath for the preview.
If the panel is to be edge lit, be sure to mirror your scene and cut it on the back side. Otherwise you will get a reflection from the back that makes you see double.
Here's my post on the test I made to check out different pressure/depth setting and stepover with a diamond drag tool. The lower squares are brighter because they are closer to the LEDs.
viewtopic.php?f=3&t=26050&p=186657&hilit=diamond#p186657
These test squares are 1/2" square. Total available depth of travel for the tool was1/2"
The example below was cut with a VCarve toolpath, 90 degree V bit, .03 flat depth, .005 stepover, before I got my diamond drag bit.
FixitMike
Postby martin54 » Tue Oct 17, 2017 9:23 pm
Mike has pretty much covered it but also try a search on the forum, lots of posts & useful info which should give you everything you need to know :lol: :lol:
Postby robertf » Wed Oct 18, 2017 1:56 am
Ok I found the diamond drag tool under specialist. When I click it there are no specs for it.
Does not appear to be a useable tool. Can I put in the parameters & how do I do it?
I'm on Aspire 9.01, Do I have a problem there ??
robertf
Postby robertf » Wed Oct 18, 2017 2:38 am
I got it figured out Thanks for the help !!!!
robertf
Return to Aspire - General
