Advice on exporting DXF from Illustrator
Postby Dadders » Mon Oct 16, 2017 10:16 pm
Please can someone help me.
When I export a DXF from Illustrator and import into Aspire and create a tool path the lines in the design break apart.
I currently export the DXF from Illustrator as AutoCAD Version R13/LT95 should I not use this setting?
Thanks in advance.
Matt
Dadders
Model of CNC Machine: China CNC Router 3040
Re: Advice on exporting DXF from Illustrator
Postby martin54 » Tue Oct 17, 2017 12:24 am
Have you tried saving as earlier versions? Not sure what version would export the best as I always export from the vector based software I use as EPS.
Exporting as EPS will generally give you a cleaner file with far fewer nodes than DXF
Postby mtylerfl » Tue Oct 17, 2017 12:53 am
I've had good luck with R12 imports - a fairly generic version. I THINK R12 is the version that Vectric products use for exporting DXF files from Aspire and VCP.
Aside...I also have good luck with AutoCad 2004 DXF version (for a different software though...I don't recall trying importing AC 2004 DXF into Vectric software)
Return to Aspire - General
Users browsing this forum: Google [Bot] and 18 guests
