Diamond Drag Bit
Diamond Drag Bit
Postby fredfow3 » Wed Oct 11, 2017 1:28 am
Hey all,
Any suggestions on a good diamond drag bit? There are a few out there and was wondering if anyone had a comment. Also, does Aspire support Drag Knife's for vinyl cutting?
TIA,
Fred
fredfow3
Model of CNC Machine: Laguna Swift 4x4, Shapeoko S3 XL
Re: Diamond Drag Bit
Postby rig gap » Wed Oct 11, 2017 1:57 am
I've been playing with the idea of a vinyl cutter, and instead of a diamond drag knife, I got a "CBO9" blade holder and an assortment of carbide blades on Amazon. I made an adaptor to hold the cbo9 and attach it in place of my dust collector.
I used V-carve pro to design a simple stencil to test on a scrap piece, and it worked perfectly the first time. The cbo9 is adjustable for cutter "stick out", and I made mine so it floats against the surface of the vinyl so any variation in the surface (table, etc.) doesn't affect the cut. The cutter blades are 30,45, and 60 deg. angled. I used the 45 deg. without having to create a corner rotation move because the blade is so small diameter.
rig gap
Model of CNC Machine: Home built aluminum and steel 3 X 4 CNC
Postby John Murphy » Wed Oct 11, 2017 3:29 pm
I have been using the Widget Works vinyl knife and diamond drag tools for years.
Both are well made(the diamond drag tool could be a little tighter for my personal preference) and I've had years of trouble free service from both.
Yes, they do seem a little pricey, but they are professional grade, and they've paid for themselves many times over.
John Murphy
Model of CNC Machine: AXYZ 5010
Postby Xxray » Thu Oct 12, 2017 1:36 am
No need to go into sticker shock, this one IMO is as good or better than anything out there
http://www.ebay.com/itm/1-4-DIA-DIAMOND ... Zz3dSMEE6g
[might want to buy a couple extra tips with the $$ you save] - They last almost forever, depending on how much you use them and on what material, eventually they will wear down.
Doug
Xxray
Return to Aspire - General
Users browsing this forum: Google [Bot] and 8 guests
