Off center pyramid
Off center pyramid
Postby atripp » Thu Oct 05, 2017 6:47 pm
How would I go about making a pyramid where the high point is off center and two of the base lines are different dimensions. In the attached photo, the blue lines represent an elevation view. The drawing on the right is a side view with the pyramid laying flat. There will be 4 pyramid's put together to form a base.
atripp
Model of CNC Machine: Anderson Exxact, Limtech Pegasus
Re: Off center pyramid
Postby mezalick » Thu Oct 05, 2017 8:29 pm
How about a simple 2 rail sweep ?
Michael
Pyramid 2.crv3d
(60.5 KiB) Downloaded 56 times
Michael Mezalick
https://carveddetails.com/catalog-book/
mm@mezalick.com
mezalick
Postby atripp » Thu Oct 05, 2017 8:39 pm
So what would I use for the guide rails and profile. I got this way but how about the other way.
atripp
Postby mezalick » Thu Oct 05, 2017 8:54 pm
If you look at my file you'll see a very, very, very small rectangle in the center of the layout.
That and the outer rectangle are the 2 rails....
You'll need to put on your "special" reading glass for this one.
~M
Michael Mezalick
mm@mezalick.com
mezalick
Postby atripp » Thu Oct 05, 2017 8:59 pm
Sorry bud, I failed to even see that you had attached a vectric file. If I can't see the file how will I see the rectangle :D , will download and study. Thank you.
Andy
atripp
Postby atripp » Fri Oct 06, 2017 12:41 pm
Mike,
Where did you get the width (9.1362) of the sweep profile? I know you got the height from my cross section dimension.
Thank you.
Andy
atripp
Postby dealguy11 » Fri Oct 06, 2017 3:04 pm
Width of the profile doesn't really matter as long as you have the rails set up with the right width and you set the model height to the exact height it needs to be. It will automatically adjust the profile to the width of the rails.
Steve Godding
dealguy11
Postby atripp » Fri Oct 06, 2017 3:18 pm
Thanks.
atripp
Postby ohiolyons » Fri Oct 06, 2017 8:16 pm
Very slick Michael
CNC in Kettering, Ohio
ohiolyons
Model of CNC Machine: Laguna IQ HHC, 3HP
Return to Aspire - General
Users browsing this forum: No registered users and 16 guests
