Hi,
Up until now I have never had an issue opening Illustrator (ai) files. Some files can take up to 5 mins to open up. These files aren't large in size and I'm just a little perplexed as to why this is happening. My computer is virtually brand new and is built primarily for gaming so there should be no problem with processing. As I say, when I first got the computer, files opened up very quickly.
I'm interested to know if anyone else has experienced this and what they did to overcome it.?
Thanks in advance.
Problem with time taken to open Illustrator files
- Vectric Staff
- Model of CNC Machine: Craft CNC DS1
Re: Problem with time taken to open Illustrator files
Mohamed
Mohamed
I save my AI files as pdfs and use the pdfs. I have noticed that my relatively simple vector files will convert with way too many nodes in Aspire. It is a good idea to check the node editing and see if that could be the problem. Then convert those nodes into smooth curves. The conversion will also sometimes duplicate these paths on top of each other making for many more nodes.
- Model of CNC Machine: SCM Record 2 and Procam
Hi mwlyod,
Thanks for the reply. Unfortunately that's not it. When the ai file eventually opens the nodes are where they should be .ie. 2 nodes for start and finish of straight vectors and a few for beziers etc.
Thanks anyhow.
Thanks anyhow.
