Profile toolpath on top of 3D model
Postby pblackburn » Tue Oct 03, 2017 1:58 am
Need some help. I cannot figure out how to do an outside profile Toolpath of some block text vectors that are on top of a 3D model. If someone knows how to do this, and if you could kindly explain it to me it would be greatly appreciated. Thanks in advance.
pblackburn
Model of CNC Machine: Mechmate with Mach3
Re: Profile toolpath on top of 3D model
Postby highpockets » Tue Oct 03, 2017 2:08 am
Model the text and add it to the 3D model.
Postby pblackburn » Tue Oct 03, 2017 2:15 am
I have the text model but I would like to profile around the outside of the text vectors and have it follow the 3d model contour underneath. It would leave a smoother finish on the block text versus the raster 3D Finishing Toolpath. Plus I have found with really thin block lettering it if I profile down to almost the surface of a model there is less chance of breaking/chipping off.
pblackburn
Postby highpockets » Tue Oct 03, 2017 2:46 am
Using the dome and text as an example.
Hide the text component.
Do a roughing and finish toolpath on the dome with outline of dome vector and outline of text selected. Use an negative boundary offset of just a little less than half the diameter of the tool that will be used to profile the text in the next step.
Create a profile toolpath of the text, set the Cut Depth to something really shallow .0001 and click Project toolpath onto 3D object.
To have the top of the text follow the dome:
Unhide the text component,
Do a roughing and finish toolpath, use the Selected Vector Machining Boundary with just the text vector selected.
Hope this makes since....
Postby pblackburn » Tue Oct 03, 2017 10:27 pm
Thanks Highpockets,
I found that you have to add an offset allowance of 1/2 the tool diameter if using the 'Project toolpath onto 3D Model' even when the vector selection is set to outside or else it cuts as if 'On' is selected and the cut depth is set to 0.0 or 0.0001. This does not have to be done when 'Project toolpath onto 3D Model' is unchecked but without this a cut depth must be specified and the model will be shaved (we knew that though). That was done with the Text model turned off. I will make a video of that to send to support as I do not believe that is supposed to happen that way. Thanks for your help
pblackburn
Return to Aspire - General
Users browsing this forum: Paul Z and 30 guests
