Wrapping post help
Wrapping post help
Postby crpoj13 » Sun Sep 24, 2017 7:07 pm
I have an issue with my post I need my post to put out a feed rate on each line and I cannot figure out how to tell post processor to do this. I'm running Mach 3 I'm not sure if there is a setting in mach3 which will enable this to work or not any help on this would be great thanks.
crpoj13
Model of CNC Machine: cncrouterparts 2448
Re: Wrapping post help
Postby Mike-S » Sun Sep 24, 2017 7:55 pm
Not sure if I understand, is this what you're looking for:
Mike-S
Postby crpoj13 » Sun Sep 24, 2017 8:16 pm
What I'm looking to do is in my posted G-Code I need there to be a feed value on each G1 line. What's happening now is the very first G1 line it puts out a feed value but every other G1 line there is no feed value, so in mach3 when Irun a file once it gets to a G1 line without a feed value mach3 just sits & does nothing.
In my other cam systems there is a feed rate on each line of code and mach3 runs as expected.
crpoj13
Postby Mike-S » Sun Sep 24, 2017 8:42 pm
Example: G-code to cut two boxes and a circle:
Are you saying that the hi-lighted values don't appear in your G-code?
What PP format did you select to save as?
Mike-S
Postby crpoj13 » Mon Sep 25, 2017 12:12 am
Think I solved it. It turns out that it needed the G94, I had a G93 and with this code a F value is required on each G1 line.
crpoj13
Postby dhellew2 » Thu Sep 28, 2017 5:01 am
In most instances, the F remains set until another F changes it. It isn't usually necessary to have it in each line. Dale
Dale
dhellew2
Postby Greolt » Thu Sep 28, 2017 7:28 am
G94 is units per minute
G93 is inverse time feed rate mode
Vectric software is not capable of producing G93 code. At least not that I am aware of. :)
Greolt
Model of CNC Machine: 900 x 750 2hp Mach3 Router & others
Return to Aspire - General
