Mini grandfather clock
Postby Hurricane » Sat Sep 23, 2017 1:08 pm
base_part_1
has add on decorative edge instead of merge making part 1.5" tall... FYI
Hurricane
Model of CNC Machine: K2 4 axis
Re: Mini grandfather clock
Postby mtylerfl » Sat Sep 23, 2017 2:53 pm
Hurricane wrote:base_part_1
Thank you for reporting that. Actually, there is a model called "Component 1" in the Component tree and it is a duplicate of the Decorative Edge model. It should either be turned off (un-check it) or you can delete it altogether. After it is un-checked or deleted, all will be well.
Only these three components should be active/visible in the component tree and in the 3D view:
- Base Limit
- Center Fill
- Decorative Edge
I'm sorry for the confusion. I don't recall why I didn't delete "Component 1" before submitting the distribution files, nor can I explain why no one has reported this before. Lots of people have made the clock, but none reported the duplicate component. Almost makes me think I did at least un-check it, but maybe it gets re-checked when opened in newer software versions somehow? Unlikely - but I have to blame something besides me! :D
Postby Hurricane » Sat Sep 23, 2017 10:04 pm
ok tks for reply... i just put it as merge and all worked...
Hurricane
Postby mtylerfl » Sat Sep 23, 2017 10:14 pm
Hurricane wrote:ok tks for reply... i just put it as merge and all worked...
That will work because that just combines (merges) the duplicate with the "keeper". Since the two models are identical, the merge is effectively "invisible". This gives the visual impression of a single model component.
In any case, I am very happy you are good to go! Thanks again for your feedback.
Return to Aspire - General
Users browsing this forum: Google [Bot], oldlogtrucker, TSM2018 and 16 guests
