Bitmap trace?
Bitmap trace?
Postby keastab » Thu Sep 21, 2017 7:38 pm
I have the v9 of aspire and seem to have lost the option to do a bitmap trace. is it hidden somewhere? I like the new make from bitmap but I usually need to get bits and pieces to make from the bitmap and not all of it. I'm still looking in the menus, but have not found it so far. I am trying to get the L R and eagle in as separate entities. I will end up making it a 3 piece STL that I can manipulate for my friends sign logo.
part of the trace I need.
keastab
Model of CNC Machine: Solsylva vbearing 45"x72"
Re: Bitmap trace?
Postby Adrian » Thu Sep 21, 2017 7:41 pm
It's in the same place and is the same icon as previously. First icon on the bottom line under Create Vectors on the Drawing tab.
Re: Bitmap trace?
Postby keastab » Thu Sep 21, 2017 10:23 pm
Adrian wrote:It's in the same place and is the same icon as previously. First icon on the bottom line under Create Vectors on the Drawing tab.
DUH! :oops: :roll: ,
Thanks for some reason I always used the V8.5 drop down menu and never looked at the drawing icons at all.
keastab
Re: Bitmap trace?
Postby keastab » Sun Sep 24, 2017 3:45 pm
thanks again for all your help. here is what I cam up with and will see if my boss likes the raised letter version I'm thinking maple for a wood to cut it on.
raised letter logo
keastab
Re: Bitmap trace?
Postby redwood » Mon Sep 25, 2017 6:23 pm
It looks like your letter spacing could use a little tweaking, but good go.
redwood
Model of CNC Machine: Axiom Pro6
Re: Bitmap trace?
Postby keastab » Sun Oct 01, 2017 8:39 pm
redwood wrote:It looks like your letter spacing could use a little tweaking, but good go.
hey glad you noticed it.
I've been object blind since I started tracing this thing out and didn't even see it till you posted about it. It's fixed now and Hopefully ready to cut since it's on the table now and finishing up cutting the roughing part. whew, Takes a bit of time if you do all 3d.(cheated and used pine for the first try) I'll look into doing pocket cuts on the next one for the letters other objects in the borders since I think that would be a lot faster to cut .
keastab
Return to Aspire - General
Users browsing this forum: No registered users and 21 guests
