Pinning Toolpaths Pane Open
Postby AlbertaClipper » Sat Sep 16, 2017 8:02 pm
Is there a way to pin the Toolpaths pane open so when a file is opened it is already pinned like the Drawing pane is pinned open?
AlbertaClipper
Model of CNC Machine: Home Built
Re: Pinning Toolpaths Pane Open
Postby Adrian » Sat Sep 16, 2017 8:27 pm
Yes, it's the same as the drawing toolpath. There is a pin on the top right which will lock it open. Make sure you set the relevant options under Edit/Options to save layouts or you'll have to do it every time. The defaults are only saved if you open Aspire directly rather than via a file as well.
Postby AlbertaClipper » Sun Sep 17, 2017 1:17 am
Adrian wrote: Make sure you set the relevant options under Edit/Options to save layouts or you'll have to do it every time. The defaults are only saved if you open Aspire directly rather than via a file as well.
Thanks, Adrian. You da Man!
AlbertaClipper
Postby Martin Reid » Sun Sep 17, 2017 11:58 am
You can 'float' both the 'panes' if you have the room on the screen.
Pin open then drag the 'bar' handle.
Drag Floating
Sincerely Martin
Martin Reid
Model of CNC Machine: Shopbot
Return to Aspire - General
Users browsing this forum: andyb, fogbow and 19 guests
