Pinning Toolpaths Pane Open
- Model of CNC Machine: Home Built
Is there a way to pin the Toolpaths pane open so when a file is opened it is already pinned like the Drawing pane is pinned open?
Re: Pinning Toolpaths Pane Open
Yes, it's the same as the drawing toolpath. There is a pin on the top right which will lock it open. Make sure you set the relevant options under Edit/Options to save layouts or you'll have to do it every time. The defaults are only saved if you open Aspire directly rather than via a file as well.
Thanks, Adrian. You da Man!Adrian wrote: Make sure you set the relevant options under Edit/Options to save layouts or you'll have to do it every time. The defaults are only saved if you open Aspire directly rather than via a file as well.
- Martin Reid
You can 'float' both the 'panes' if you have the room on the screen.
Pin open then drag the 'bar' handle.
Sincerely Martin
Sincerely Martin
