Still Having a Modeling Issue
Postby PiedmontSlim » Mon Sep 11, 2017 6:04 pm
This should be simple, but I've been fighting it for days. As a newbie I'm trying to figure it out.
I'd thought I'd start simple, an easy guitar body. I'm trying to put a taper on the heel.
I create the rails. If I use a straight line for the profile I almost get what I want. But, I want a slight arch.
If I put any curve at all in the profile line I get a mess.
I've played with rail order and direction, adding, subtracting.
Any help would be much appreciated. Thanks
PiedmontSlim
Model of CNC Machine: Legacy ARTY
Re: Still Having a Modeling Issue
Postby mezalick » Mon Sep 11, 2017 6:47 pm
Two rail sweeps can be tricky.
Here's an eps file for you to try.
It has the two rails and the profiles.
See the attached pictures for help...
The trick is to make the component bigger than you need and to then trim it using the vectors of the guitar body..
Hope this helps.
Michael
2 rail sweep.eps
(4 KiB) Downloaded 63 times
Michael Mezalick
https://carveddetails.com/catalog-book/
mm@mezalick.com
mezalick
Postby PiedmontSlim » Mon Sep 11, 2017 6:54 pm
Thanks much. I'll use the file, but I'd like to figure out what I'm doing wrong.
Eric
PiedmontSlim
Postby PiedmontSlim » Mon Sep 11, 2017 7:19 pm
Getting closer. Now I have to figure out the trim thing
Figured it out. Thanks much
PiedmontSlim
Return to Aspire - General
Users browsing this forum: Google [Bot] and 23 guests
