adding a knot to wood grain
Postby redwood » Wed Sep 06, 2017 3:06 am
I have a sign that I'm using a non tilable wood grain texture to. I would like to add some knots, any ideas of how to do that?
redwood
Model of CNC Machine: Axiom Pro6
Re: adding a knot to wood grain
Postby highpockets » Wed Sep 06, 2017 6:40 am
How are you applying the wood grain texture?
Postby redwood » Wed Sep 06, 2017 7:52 am
It's a non tilable texture that comes with Aspire. It uses a 3D finishing tool path. The sign is a replica of a Tavern sign in Portugal.
If need be, I'll just try and find a board with knots already, but it would be interesting if anyone had a idea how to do it.
Here is the original sign.
redwood
Postby Mike-S » Wed Sep 06, 2017 4:24 pm
Try playing with the Sculpting tool. Smooth an area and then Deposit new grain lines around your knot.
Mike-S
Postby highpockets » Wed Sep 06, 2017 4:41 pm
Mike sort of beat me to it :D :D :D As alternative to sculpting, you might Google wood knot images, pick one you like, import the image as a component and merge it with your existing texture.
Postby Mike-S » Wed Sep 06, 2017 5:04 pm
Highpockets, we're thinking alike. I gave the merge a try first, but kept getting the original grain intermingling with the new knot--just didn't look right. Also tried "Distorting" the original grain, but that was a disaster.
Mike-S
Postby redwood » Wed Sep 06, 2017 5:41 pm
Thanks for the ideas. I hadn't given sculpting a thought. I'm pretty amateur in using a lot of the modeling tools, but I'll give it a shot.
redwood
Postby highpockets » Wed Sep 06, 2017 5:50 pm
Mike,
Just noodling around a bit, the know on the left is the original, I did a rough cut out then rotated it 90° (just for contrast on the test), removed some of the edge to taper it a bit (sure wish there was a fade you could apply all the way around a component). Flattened it out quite a bit, merged it with the original and played with the base height a bit.
This is the kind of thing you could spend hours noodling around with :D :D :D :D
Postby Mike-S » Wed Sep 06, 2017 6:46 pm
Possibly the "Multiply" function. Look at Vectric's tutorial on that.
Mike-S
Postby highpockets » Wed Sep 06, 2017 7:19 pm
Mike, I've yet to figure out the Multiply option.
Return to Aspire - General
Users browsing this forum: Xxray and 20 guests
