V9 turn icon
V9 turn icon
Postby sawmiller » Sun Sep 03, 2017 9:20 pm
been poking around V9 a lil, and had this thought, the turn and spin seems a shoein for the rotary work.
but as far as i can see you would have to create a silhouette, turn the spindle, export as stl,unwrap, then use that for a wrapped job.
is there a easier way to go from turn to rotary?
dan
In the heart of Tn
sawmiller
Model of CNC Machine: joe's rack and pinion hybrid
Re: V9 turn icon
Postby mezalick » Mon Sep 04, 2017 12:45 pm
Sawmiller,
How about the Molding Toolpath..
Create a wrapped job.
Create your profile shape.
Use the drive rail in the Molding toolpath.
Cut it.
It is much better than the turn option as this does not create a component which is affected but the quality of the pixels...
The first attached picture ( Long Spindle ) was made using the molding toolpath tool and the fluting toolpath tool.
The second is just the molding toolpath tool.
Michael
Michael Mezalick
https://carveddetails.com/catalog-book/
mm@mezalick.com
mezalick
Re: V9 turn icon
Postby sawmiller » Tue Sep 05, 2017 2:10 am
thanks Micheal , i'll try that
dan
In the heart of Tn
sawmiller
Re: V9 turn icon
Postby bravesoul » Tue Sep 05, 2017 1:27 pm
Michael,
I'm a bit old and slow on the new stuff but I have been able to create some turned items on my lathe/indexer the normal way. I was wondering if you would mind posting the file on the above so I could try to figure out how you accomplished your turned spindle using the moulding toolpath?
Joe Barrow
bravesoul
Model of CNC Machine: ShopBot PRT ALPHA 48"x96"
Re: V9 turn icon
Postby mezalick » Tue Sep 05, 2017 1:47 pm
Sure Joe,
Here's a quick example of the molding toolpath to create a turned item...
The one thing many people get incorrect is that the profile works when it is in the horizontal position......
So, I usually draw the profiles in the vertical,to check for correctness and then rotate then to the horizontal.
Let me know if it works for you.
Michael
Molding toolpath example.crv3d
(157 KiB) Downloaded 45 times
Michael Mezalick
mm@mezalick.com
mezalick
Re: V9 turn icon
Postby bravesoul » Wed Sep 06, 2017 12:13 pm
Michael,
That helps, Thanks for the example.
One more question, how did you do the spiral with the moulding toolpath?
Joe
bravesoul
Re: V9 turn icon
Postby bravesoul » Wed Sep 06, 2017 12:17 pm
Opps, I just reread your post, you use the fluting toolpath. Would you mind showing that example too please.
I have a sizable job to finish this week but after that I want to start playing with my indexer some more.
Joe
bravesoul
Re: V9 turn icon
Postby mezalick » Wed Sep 06, 2017 1:15 pm
Joe,
The fluting toolpath is a gadget that you'll need to install.
http://gadgets.vectric.com/V9/fluter.html
And the best way to explain it would be to listen to the Master Himself,,James Booth
https://www.youtube.com/watch?v=8LIs6YCB5O4
Or better yet,,take a look at the Help Manual and check for " Wrapped Fluting Layout"
Michael
Michael Mezalick
mm@mezalick.com
mezalick
Re: V9 turn icon
Postby bravesoul » Fri Sep 08, 2017 12:02 pm
Thanks Michael,
I sometimes forget about the tutorials, will go through them before asking for more help :oops:
Joe
bravesoul
Return to Aspire - General
Users browsing this forum: No registered users and 18 guests
