Radius All Corners Bug
Postby garylmast » Thu Aug 31, 2017 2:49 am
I was drawing a design and used the Radius All Corners Gadget. It worked just fine except the corners were more than I wanted. I tried to Undo it but it would not let me. I had to redraw all the vectors again, which took awhile. This time I copied the vectors before I used the gadget, which was still more than I wanted, but I was able to delete the vectors and paste it. I hope the bug can be fixed, because my memory is only about 30-seconds, and I know I'll forget to copy and have to redraw everything again if I use the gadget again. I'm using the Aspire V. 9.010. Gary
garylmast
Re: Radius All Corners Bug
Postby BrianM » Thu Aug 31, 2017 5:54 am
This is not a bug as such, it has always been a limitation of ALL gadgets that they don't work with the undo mechanism as they operate at a very low level in the program when creating geometry etc.
Brian
Brian Moran
Managing Director
Vectric Ltd.
BrianM
Vectric Staff
Postby Adrian » Thu Aug 31, 2017 6:19 am
The gadget has the (default) option of creating the radiused vectors on a new layer. If you always use that then you won't lose your starting vectors.
Postby garylmast » Thu Aug 31, 2017 12:18 pm
Thanks for the reply. Gary
garylmast
Return to Aspire - General
Users browsing this forum: No registered users and 21 guests
