Tree face problem
Tree face problem
Postby cabledog_68 » Sun Aug 13, 2017 12:40 am
Hello guys and gals. I have a problem i cant quite figure out. I downloaded the Tree face file. When i went to run it. I got a z0 error. I am fairly new at this. So i am having an issue fixing this. Thanks
cabledog_68
Model of CNC Machine: stepcraft
Re: Tree face problem
Postby mtylerfl » Sun Aug 13, 2017 1:52 am
Hi Bill,
Perhaps I can add a little more clarification regarding the problem you are having...
- You are trying to run the free Tree Face Vectric project: http://www.vectric.com/cool-stuff/proje ... -face.html
- The project is set with the Z-zero at the top of the 0.75"-thick material. When you attempt to run the project at your machine, you receive the soft limit error and cannot run the project.
Does anyone have any ideas/suggestions for Bill why he is having this problem?
Postby cabledog_68 » Sun Aug 13, 2017 2:07 am
Yes, what he said. lol
cabledog_68
Postby vip-klaus » Sun Aug 13, 2017 11:36 am
I think maybe you have a problem of understanding the difference between machine coordinates and workpiece coordinates. If you set Z0 to the top of the material, it should correspond to a negative Z value of the machine coordinate. Z0 of your machine should be at the highest position your router can reach.
Where is your machine origin in X, Y, Z?
vip-klaus
Model of CNC Machine: Wabeco F1410 LF-C HS; Sorotec AL1110
Postby Adrian » Sun Aug 13, 2017 12:04 pm
Make sure that Z1, Z2 and Home Z positions in the Material Setup are sensible for your machine. If your machine can only move, for example, 2" upwards when set at the top of the material you don't want any of those values to be more than 2" at the absolute maximum.
Postby martin54 » Sun Aug 13, 2017 12:15 pm
Are you trying to cut this using the files supplied by Michael or have you toolpathed it yourself so it is suitable for your machine?
If I were to try & cut this job on my machine using Michael's set up & toolpathing I would get an error as well. :lol:
My machine has a max z travel of about 2" If I were to use Michael's figures where his home position is set 1.8" above the material surface then with 0.75" my z axis would exceed the maximum travel :lol: :lol: :lol:
Postby ger21 » Sun Aug 13, 2017 1:03 pm
If you don't have a Z axis home switch, turn off your Z axis Softlimits.
If you do have a Z axis home switch, are you homing the Z axis before setting Z zero?
Gerry
ger21
Postby mtylerfl » Sun Aug 13, 2017 1:06 pm
Hi Bill
Adrian and Martin bring up a very good point about double checking that all the material and toolpath settings are suitable for your machine.
Try changing the Home Z to an amount smaller than 1.8" (an amount you are sure won't exceed the Z limit of your machine).
Return to Aspire - General
Users browsing this forum: sjwiehe, Yahoo [Bot] and 23 guests
