Moving all Vectors on a 2 sided job (Aspire V9)
Postby hooked » Thu Aug 03, 2017 11:25 pm
I think I'm missing something really simple here. I want to select all vectors on both sides of a two sided job and move them. I'm sure there will be a process to do this but I cant seem to easily achieve it. Help appreciated.
hooked
Model of CNC Machine: SCRATCH BUILT CNC ROUTER
Re: Moving all Vectors on a 2 sided job (Aspire V9)
Postby highpockets » Thu Aug 03, 2017 11:43 pm
I'll be watching this thread, I haven't found a way to move vectors on both sides at once either.
Postby mezalick » Thu Aug 03, 2017 11:55 pm
One way would be to right click on the vectors on whatever "side" you're working on and then select "move to other side".
At that point you can move all vectors to a new layer.
Michael
Michael Mezalick
https://carveddetails.com/catalog-book/
mm@mezalick.com
mezalick
Postby highpockets » Fri Aug 04, 2017 12:08 am
mezalick wrote:One way would be to right click on the vectors on whatever "side" you're working on and then select "move to other side".
Michael
The only thing I'd add to that is before moving the vectors to the other side would be to group them after selection. This would prevent, or help prevent, mixing the vectors of the two sides.
Good work around Michael.
Postby mohamed » Fri Aug 04, 2017 12:28 am
There is no 'official ' way to move vectors on both sides yet, but we're aware that it would be useful. It's yet to be decided how to do that without the confusion and potential errors arising from having vectors / components that you can't see selected.
Your input is always welcome of course
Mohamed
Mohamed
mohamed
Vectric Staff
Postby highpockets » Fri Aug 04, 2017 12:44 am
Thanks for the information Mohamed.
If you have double sided view toggled on all vectors on the opposite side show in blue. Could you also have the components show in blue? Then in the tool windows for the Transform Object section of the Drawing tab have a check box to transform both sides? While I'm wishing, it would be nice to be able to select one, multiple or all vectors/components from the opposite side.
Just my two cents.
Postby hooked » Fri Aug 04, 2017 1:42 am
Well, now that I know that there is no simple key stroke, I just move the vectors on each side the same set amount. Would be great to see a SELECT ALL VECTORS - BOTH SIDES option available within the software.
hooked
Return to Aspire - General
Users browsing this forum: Google [Bot] and 19 guests
